- May 23, 2015
- 24,433
- Plaster
- Pentair Intellichlor IC-60
pH is fine. You don't have to test CYA, once you know it, it does not change unless you have significant water exchange.
Your FC was consumed by algae and organics. You need to get your FC up to 28ppm and maintain it. It's going to take a lot of chlorine to get there and, initially, it's not going to hold because it's going to get used up killing everything. So be prepared to add what PoolMath tells you to and test very frequently in the beginning, like every two hours. Eventually the chlorine will start to hold. You're going to have to baby sit this pool for a day or so until it starts holding FC.
Going forward, the only thing you need to measure is FC and CC and add chlorine as-needed per PoolMath.
