Hello again everyone!
I'm deep into my DIY Reno and have a quick question for the experts concerning my CMP/Brilliant wonders niche less 1.5" LED lights. With the propensity of LED lights failing over time for heat related/leak issues due to: 1. LEDs overheating and burn out. 2. Potentially drawing water into the LED body during "Heat up" and "Cool down" cycles as the light is powered on/off. 3. Improper winterization resulting in cracked LED body.
Typical installation of these lights utilizes a standard external 1.5" wall fitting and 12" length (min.) of 1.5" pipe that transition down to 3/4" or 1" for the wire run.
The lights are niche less but not necessarily a dry install.
Question: Do you think it would be advantageous to install an internal 1.5" wall fitting and 12" length (or longer) of 2" pipe (vice 1.5") to provide a better heat sink? Or am I fretting over something and complicating this install for a non-issue?
Photos of the Demo.
Thank you all for the help! Jeff
Photos of the Demo.
