i have a few items i am trying to figure out as this pool (house) is new to me. i know this is alot but any help would be great. I have had a liner pool and a fiberglass pool but never a plaster (i move alot I know) so here goes
-i have two skimmers in this pool neither seem to pull has hard or fast as the single skimmers i had in my other pool is this normal? there is a little cover i can slide over the inlets in the skimmers to reduce to one and that does help but not sure the point in that?
-i was told we can swim right away but need to brush the pool every other day or so, if i get a robotic cleaner do you still need to brush the pool all the time or does that basically take the place of it? also what is the recommended cleaner for robotic ones? I see alot about dolphin on here.
-there are two 1/4 inch pvc lines that come out under the edge of the hottub on the pool. they go out to the decking around the hottub. when we run the jets they gurgle some but no water is this some sort of air intake for the hot tub? never seen anything like it before.
