I recently had an IC40 SWG installed on my pool and I have a few questions related to the install:
(If it’s relevant, below are my test readings:
FC: 3.5
pH: 7.6
Alk: 80
CH: 425
CYA: 60
salt: 3400 ppm)
1) my water is ~2 years old and had previously used the liquid chlorine method. Before I bought / added any salt for my pool I tested the salt levels and got a reading of 3400 ppm. Is this a realistic level if I’ve only ever been putting liquid chlorine and muriatic acid in the pool? For what it’s worth, the IC40 tells me my salt levels are good with the solid green light.
2. I have a Pentair variable speed pump. What is the lowest RPM I can run it at and still create chlorine?
3. My pool is 30,000 gallons. After doing research post-Install, I realize I should have sized up to a 60,000 gallon rated SWG, but hindsight is 20/20. Realistically, what can I expect with an undersized SWG unit? Any tips or tricks to keep it running ok in this scenario? Will I need to run it at a higher percentage to compensate for this?
4. The SWG is hooked up to an old school dial manual timer. Can it be left on at all times, or is it better to have it only come on when my variable speed pump kicks on?
5. Is there a best time of day to have the SWG running? Morning, afternoon, nighttime?
Thank you in advance for your help!
FC: 3.5
pH: 7.6
Alk: 80
CH: 425
CYA: 60
salt: 3400 ppm)
