I am doing some research just trying to understand the chemistry behind the Chlorine / CYA chart and came across an interesting article.
http://www.ppoa.org/pdfs/PrP_Cyanurics - Benefactor or Bomb.pdf.
The author argues that CYA should be kept to no more than 20 ppm in a pool maintained by hand. I'm skeptical based on what I am reading here but would love to hear your take on his claims.
Claim 1 -- that most of the "staying" power of CYA is achieved at 20 ppm.
I've attached his chart (the bottom graphic) which purports to show (1) that even at 70 ppm CYA FC will decrease by 9.9% per hour; (2) that the stabilizing power of CYA increases exponentially at first and then flattens out so that at about 30 ppm FC loss is 10% per hour (i.e. only a tiny bit worse than at 70 ppm). He does not specify temp / sunlight for the chart. Is this consistent (or at least in the ball park) with your observations of your own pools? If he is right and I am understanding all of the numbers, a pool at FC 5 ppm and 50 CYA would lose .5 ppm in the first hour resulting in FC 4.5 , after 2 hrs = FC 4.1, 3 hrs = FC 3.6, ... 8 hrs = FC 2.2. If this is true, the a starting at 10 ppm FC and 50 ppm CYA would hit negligible FC in less than 48 hours? Although maybe the chart only refers to sunlight hours in which case you'd get 3 -4 summer days before you had nearly zero FC. Sound about right?
Claim 2 -- that CYA dramatically reduces the oxidizing (and to a much lesser extent the sanitizing) power of FC.
His second chart (the top graphic) purports to show that a pool at FC 4 @ CYA 40 has the oxidation effectiveness equivalent to FC .4 @ 0 CYA (ph 7.4 / temp 76F). He also claims that at 70 ppm CYA and above any FC number no matter how high gives an effectiveness equivalent to FC .2 @ 0 CYA. The assertion jibes with what everyone has been saying about CYA - that at a certain level it becomes *practically* impossible to get any ozidizing power out of Chlorine no matter how much you put in. However, he seems to be claiming something more -- that it is *actually* impossible to get more than a FC .2 equivalent no matter how high you raise the FC. Does this square with your experience.
He cites a bunch of studies which may or may not be valid. I am really more interested in first hand experience. Once I get my test kit I am going to do a little experiment ...
