Thanks to joyce, i think i am getting a better handle on accurately reading the CYA test - black dot. I have re-tested this morning in preparation of lowering my TA:
FC 1.5
CC .5
TC 2.0
pH 7.5
T/A 240
CH 290
CYA 50
I know my T/A is too high and I have bought the muriatic acid to work on it. I also know my FC is low and the caluculator has given the amt of bleach to add to raise it (approx 1.5 gals).
I have read waterbear's article about lowering TA which is excellent. She talked about aeration, which can be used to raise my pH (after lowering my TA). I looked at attachments for types of aeration, but none seemed to fit my pool configuration. I am alo "winging it" so to speak.
I have attached a pic of what I did to get more aeration into my pool water, since my pool is not heavily used. My pool skimmer includes a trichlor compartment that i USED to fill with tablets. There is also a small water hose that runs from somewhere in the inlet, injecting pool water thru the trichlor compartment to wash over the tablets, then discharging out the side of the compartment and down into the skimmer to be circulated. Since i am now a BBB user, I disconnected the hose from the compartment, aimed it out the skimmer and into my pool (using duct tape), creating a small fountain. Do you think it is enough to be of any help to me?
Next question: I used the WONDERFUL calculator, and it is telling me I will need to add approx 60oz of muriatic acid to lower my PH to 7.2, which I believe should be my goal, since I have a vinyl liner?
Is it safe to assume I add my chemicals based on the order the tests are in on the calculator? for example, FC first, PH next, TA, CH, etc? Based on that theory, I would add my bleach first, then move on to the acid?
Last but not least - I am absolutey afraid to even open the bottle of muriatic acid. I need advice.
My pool water is clear as a bell and sparkles.
