no worries, i dont take much personallyHope that helps! (Sorry Aussieta- I this doesn't come across as having a crack!)
i was more worried op would make a dramatic attempt to lower ph/ta without the extra ch
DATE | TIME | FC | CC | PH | TA | CH | CYA | SOLAR COVER | SWG setting* | MA (ml) | CaCl2 (g) | CYA (g) | SWG change* | SWG pump runtime (hrs) since last test |
10-15-2015 | 09:49 PM | 12 | 0.2 | >8 | 120 | 210 | <30 | ON | 5 | - | ||||
10-17-2015 | 12:04 PM | 1 | 0 | >8 | 120 | 210 | <30 | OFF | 5 | 500 | 500 | 2000 | 1 | 2 |
10-17-2015 | 07:15 PM | 3 | 0 | 7.4 | 120 | - | - | OFF | 6 | 10 | ||||
10-18-2015 | 10:38 AM | 5 | 0 | 7.4 | 120 | 210 | - | OFF | 6 | 500 | 2.5 | |||
10-18-2015 | 09:16 PM | 5 | 0 | 7.6 | 110 | 230 | 40 | OFF | 6 | 0 | ||||
10-19-2015 | 09:54 AM | 5 | 0 | 7.6 | 110 | - | - | OFF | 6 | 500 | 2.5 | |||
10-19-2015 | 08:37 PM | 4.5 | 0 | 7.6 | - | - | - | OFF | 6 | 0 | ||||
10-20-2015 | 10:20 AM | 5 | 0 | 7.6 | 120 | 230 | - | ON | 6 | 500 | 2.5 | |||
10-21-2015 | 07:48 PM | 5.5 | 0 | 7.6 | 120 | 220 | - | ON | 6 | 1000 | 2.5 | |||
10-23-2015 | 10:13 AM | 6.5 | 0 | 7.8 | 125 | 225 | 40 | ON | 6 | 2.5 | ||||
10-24-2015 | 2:00 PM | 500 | 1000 | -2 | ||||||||||
10-25-2015 | 10:13 AM | 12.5 | 0 | 7.8 | 125 | 275 | - | ON | 4 | 24 |
-The solar cover should protect your FC to some extent from the sunlight. It can affect PH if the cover is left on, but taking it off provides the outgassing that is required to keep Ph steady. It shouldn't affect your other parameters too much
Thanks for the clarification Chem Geek. I just realised when rereading how this contradicts the outgassing process, required without the cover on, notwithstanding how itl leads to higher ph, especially with higher levels of TA and aeration. Without detracting from the OPs thread, just wondering if you could confim that the reduction in my ph that i am experiencing is due to the consumption of chlorine, in the absense of outgassing with the cover regularly on.
