- Aug 18, 2011
- 23
- Pentair Intellichlor IC-40
Hi, I have used TFP for over 10 years in a pool in CA that was surrounded by trees. After learning about SLAM and did the procedure it was easy to maintain without the constant shock and wait pool store routine.
Jump forward to now and I have a new SWG in ground pool. Fresh fill, liquid chlorine until salt was added. I am working on getting the SWG % and pump run time adjusted to maintain my FC target of 4 (I have high CYA thanks to pool company and will likely drain 10% of pool volume)
My question is do I need to SLAM it? There are no trees near the pool so no leaves or other debris.
Looking forward to your replies.
Here is a link to my pool logs
Current pool numbers
7650 gallons
Mostly full desert sun all day
FC 2.5
CC 0
TA 130
PH 8.5
CYA 80 ish
Temp 81
I did add acid after the test but did not retest tonight. Will test am and pm tomorrow
7650 gallons
FC 2.5
CC 0
TA 130
PH 8.5
CYA 80 ish
Temp 81
