In my case the pool had not run in at least a year, and likely longer and the CYA was at 0 on my test strips, two tests at pinch a penny and finally on my test kit too. I had picked up some dichlor shock at an ace hardware just up the street since it was at $2 a pound. Now that my test kit is showing the CYA right about where it belongs the other pound I hadn't used will likely sit around for awhile. My Ph has been on the low end all along as well and I think adding the dichlor drove it down a bit (pool math said it would so it wasn't a surprise). The hard question is that while normally Ph is ignored during a slam, but at the same time it also normally is driven up by the chlorine and drops back at the end of the slam on its own.
Sent from my DROID RAZR HD using Tapatalk
