New pool pump motor was installed, it was started up, ran for a few seconds then started smoking. After this first startup, there was spilled clear oil inside the back cover near the capacitor.
The motor will turn on and run for 5-10 seconds, then make a click sound and turn off. It's not tripping the circuit breaker. Nothing appears to be burnt around the wiring in the back panel. It's ran for less the 30 seconds in total.
The reason for the new motor is the last one burnt up last week after a particularly bad thunderstorm (for what it's worth).
It was 6 years old. It too made a loud pop, smoked and then fire literally started coming out of the bottom of it.
With this brand new one popping and smoking as well... could it be the wiring? Or was the capacitor bad on my new motor?
The motor is an identical replacement of the old one, so the specs are definitely correct.
It's wired correctly as it's just two hots and a ground. The pump is a Max-E Pro.
Could it have to do with the start switch? The metal piece that holds the springs seems off center relative to the prongs.
Any insight is appreciated!
