New Pool Recomedations
gmgm55
0
45
N. Houston
I am in the process of signing a contract for a new pool. I have interviewed a few pool builders and have settled with someone I think is trustworthy. I am looking for recommendations on what I have been quoted.
  • rectangle 40'x20' with level spa
  • Hayward Omni Logic Touch Screen Control Panel
  • Aqua Star PTF 27,000 Rated #1 in Filters (is this a better option than a traditional Hayward filter?)
  • Hayward 180 Degree valve actuators
  • Hayward Tristar VS950 2.7 HP Variable Speed Smart Pump
  • 3/4 HP Booster Pump for Pressure Side Cleaner, Polaris 280
  • Hayward Maxflow 500 for feature
  • Hayward Premium 500k NG
  • Super Pro Premium Chlorinator, Hayward Salt T-Cell
  • 12 Volt LED color changing (2-lights in pool 1-light in spa)
  • returns - 6 Pool, 6 Spa
I hope to have some renderings this week.
I’m also in the quoting stage for a pool. One of my pool builders that is quoting the project spec’d Hayward for everything. He also gave me the option for either the Hayward Omnilogic controller OR a new controller called The Attendant (made by Poolside Tech). I’m not sure what is better however I’d recommend you check out both before deciding on your pool. Good luck!
Disclaimer: I’m not a pool owner (yet)
I'd probably ditch the Chlorinator if you're doing salt anyways.
Also, the pressure side cleaner and pump is a pretty big expense that probably isn't worth it. There's plenty of good pool robots out there that will cost far less and not consume as much electricity while cleaning.
Reactions: YippeeSkippy
