I'm looking forward to seeing what tomorrow brings on the numbers. Hopefully whatever it is in there fighting it will get it taken care of. Just continue to maintain shock levels, brush/vacuum often, paying close attention to potential hiding areas.
(I couldn't see a lot of areas in the pictures, but definitely investigate the capped areas on the steps, and any other areas such as behind returns, inside skimmer, tight areas where the floor and the wall come together etc.. that may have gotten missed and have something lurking below/behind them.
You guys are doing all you can do to get this cleaned up/cleaned out. I am so proud of you both. Unfortunately, there has to be something in there somewhere that continues to cause you to have a 3.5 drop (or more) every 4-5 hours, day or night, be it the stuff that came out from behind the light the other day still causing issues, or something else lurking below/behind another area. Wishing you luck on locating the culprit soon, so your chlorine levels will finally begin to hold.
Keep us posted, and have a wonderful day.
