- Jul 4, 2019
- 230
- Vinyl
- CircuPool RJ-45 Plus
Hello everyone, I just bought a house this past year with an in ground pool. This is my first time owning or even taking care of a pool. I've been reading a lot including a lot from this forum and have found a lot of good information here. Being an engineer I appreciate the fact everyone's responses here are based around knowing the facts. Due to other stuff going on I haven't had a ton of time to spend on the pool and have been fighting algae and other issues all summer. Sorry if this post gets long but I want to give all the info I can to help resolve the issue. I have been recording pretty much everything related to pool in PoolMath (Love the app!)
Questions:
1.) I have little to no flow going through the skimmer/pump/filter. Water is definitely flowing through the pipes but despite all the leaves in the pool skimmer the basket is not filling up. Stuff gets in skimmer but does't get pulled into basket. The surface of the water doesn't look like it's moving around at all. I tried vacuuming tonight and all I seem to do is push stuff around inefficiently and ended up with very little stuff picked up. Any ideas what to check?
2.) If I decided to close the pool for the winter in it's current state, how much of problem is it closing it like it is?
Background info I think might help:
I hired a local company to open the pool so I could watch and learn. While they were opening they mentioned that there was a leak somewhere on the suction side and it was likely underground. I was skeptical based off everything I read, but decided to dig the suction side lines up anyway after checking what I could above ground. Sure enough the pipe connecting the skimmer to the pump had cracked and was now curved. My guess is previous owner didn't get water out and pipe froze over the winter. I was having trouble finding a way to connect to fitting on skimmer so I used a rubber adapter to connect the new PVC to the connector coming out of the skimmer. While not ideal I don't think any air or any large amount of air is getting in through there. Pump basket filled up with water and looked normal from what I could tell from my research. Flow was fairly strong from 1 return but not the other. I hadn't been adding any chlorine during this whole process so needless to say it turned green. I started the SLAM process and over course of next month tried to do my best to test and add bleach as often as I could, but it wasn't often enough so this dragged on.
I finally tried to vacuum for the first time about a month in (hadn't found enough time to do it). It didn't feel like it was doing anything but after going around the pool I found out I skimmer basket was full. I went on vacation and put some pucks in the chlorinator while I was away to try and not lose too much of my progress. When I returned most of the junk from bottom of the pool was in the skimmer and water was pretty clear, I was excited. Looked like there was a lot of gray debris on bottom so I decided to vacuum and brush the walls. Ever since then flow through returns was there but very slow and skimmer was no longer filling up. I thought maybe chlorinator was clogged so I decided to remove it and replace with straight pipe. That got the flow through the returns moving again for a little. It's now back to very little flow and vacuuming doesn't pick anything up.
On good note I finally measured some free chlorine after adding a bunch, so probably making some progress on the current SLAM. The picture of the pool from above is from a day or two ago, but it looks pretty similar now just more leaves.
I have been cleaning the filter as often as I can by rinsing it down with an aqua comb. I did replace the filter about a month ago.
Filter pressure: When I first opened the pool it was running at about 12 psi. Ever since I replaced the suction line it doesn't go below 20 psi.
Thanks in advance for any help!
Questions:
