Saturn94
- Mar 11, 2015
- 1,749
- Vinyl
- Hayward Aqua Rite (T-15)
I don't know who the others feel about this but I'm concerned about something - you're reading a 20ppm CYA when that's the bottom of the test tube AND you say that they have been adding trichlor tablets to your in-line chlorinator all this time AND you have no idea what other chemicals they were using.
I know you said you measured your CYA with a TF-100, but can you redo the measurement BEFORE you add anymore CYA? The CYA test is the trickiest one to do and whenever I see people posting results that are on the margins of the test (high or low), I almost always certain that the test needs to be redone.
As for trichlor use, I would advise against it. If your CYA is truly 20ppm and your pool has been clear all these years then you are indeed VERY lucky. Most pool service companies screw up people's pool water badly and over-stabilize their water (CYA > 100ppm). If your CYA is 20ppm, then I would add enough granular stabilizer (pure CYA) to get your water to 30ppm and use manual bleach chlorination going forward. Considering the nature of your pool (screened in), your FC demand from sunlight degradation should be minimal as will your contaminant load, so I would expect your pool to be very easy to maintain manually with liquid bleach. If you want to save some trichlor tabs for when you go away on vacation, that's fine. But it's simply too easy to get lazy and screw up your pool water using pucks.
You can use trichlor pucks but know this - for every 10ppm FC added by trichlor, you increase your CYA by 6ppm. So you'll only be at 30ppm CYA after about 20ppm FC added. The number of pucks that equates to will be based on your pool volume.
You need, at a minimum, 20ppm CYA in the water. CYA not only protects the FC from UV degradation, it also moderates the strength of the active chlorine (hypochlorous acid) in water. At 0ppn CYA, even 0.5ppm FC would be incredibly harsh on clothes and hair. So you must have some CYA added.
I would suggest you spend some time on the site in Pool School learning about the FC/CYA relationship as that will help guide your decision making process.
+1!!!
