Our pool was completed a week ago. It's the PB version of pebbletec.
I'm on Tapatalk so I can't add the details of the pool on a signature. So, 20,000 gallons, pool and spa. Spa falls into pool. 2 scuppers.
Using tf-100 for testing. 8.25% bleach and 31.45% muratic acid. No SWG, just going to use liquid bleach for chlorine.
Testing from 10/25
Using k-1000
Cl-1
Br-2
Ph- 8.2
Using tf-100
Cl drop test- 2
CC-0
Cya- less than 20
Calcium hardness- 300
TA- 120
So using pool math I added:
89 oz bleach
44 oz muratic acid
Today testing is:
K-1000
Cl- 2
Br-4
Ph- 8.2
Tf-100
Cl drop test- 2.5
CC-0
Cya- less than 20
Calcium hardness- 400
TA- 130
Pool math is telling me to add:
118 oz bleach
71 oz muratic acid to get pH to 7.3 (since I assume it will continue to climb with new plaster and scuppers)
The CSI says it is .95, but I'm not sure if that should be a focus right now.
I know I also need to get som CYA into pool. Should I target 40?
Thanks for any help.
Testing from 10/25
Using k-1000
Cl-1
Br-2
Ph- 8.2
Using tf-100
Cl drop test- 2
CC-0
Cya- less than 20
TA- 120
89 oz bleach
44 oz muratic acid
Today testing is:
K-1000
Cl- 2
Br-4
Ph- 8.2
Tf-100
Cl drop test- 2.5
CC-0
Cya- less than 20
TA- 130
118 oz bleach
