I have a 15' x 42" Bestway above ground pool. From the website, I see that it holds 3,955 gallons at 90% capacity so I'm guessing that is about where I'm at on volume. I couldn't find the volume calculator in the PoolMath app, so if someone can point me in the right direction for that, I'd appreciate it.
I filled the pool on July 10th and the first thing I did was start using a Remington Solar Ionizer, which after reading many threads in this forum, I now think was a bad decision. Especially with the size of my pool. When testing with one of the copper test strips, I hit the max level of 2 on the chart, so maybe it's even higher than that. I'm not overly concerned about the copper, but from what I gather, the only thing I can do to get rid of it is drain the pool. Ugh!
I don't have a test kit - only strips that test for chlorine, ph and alkalinity - and a separate strip for testing copper. I don't mind getting a test kit, but hadn't planned on that expense. I understand it could save me $$$ in the long run, though.
I haven't started adding chlorine or anything yet. I'm kinda frozen at this point. I've read the guide for seasonal pools. I've read the SLAM protocol. I've read too much! I suspect my water is starting to get icky! But... the test strip shows basically nothing for chlorine, ph and alkalinity because I haven't added anything besides copper at this point. I need to do something! The good news is, that after tons of reading, I have a much better understanding of how all of these levels work together.
Can I: Ignore the copper and start the seasonal pool process? CYA, then PH and then FC?
Can I: Ignore the copper and start the SLAM process? Can this even be done if I'm kinda starting from scratch? No current chemicals, but possibly some algae?
Should I drain and refill and start one of the above? I'd rather not, but will if I need to.
I'm ready to take some action and appreciate the help!
