Hi everyone, we have a new pool installed, approx 15000 gallon, chlorine, pebble plaster. I have a Taylor k2006 kit that I have been monitoring chemistry. At the advice of builder, pool school guy, I bought 50 lbs of trichlor tabs and 25 lbs of dichlor. I asked about these increasing cya and was told it would take a while to get too high, then just drain and fill. We filled in late March and since I've been using about 3 tabs per week in chlorinator. Aside from that, basically just adding acid to offset plaster cure pH increase, and occasionally alkalinity up.
After reading more here, I started watching my cya, since I learned both trichlor and bichlor increase cya rather significantly. I'm now at about 55-60ppm.
So, I'm planning to get some liquid chlorine and switch to that. But, I don't want to waste the stuff I already bought, so I'm thinking of throttling back the chlorinator and supplementing with the liquid. Any issues with this?
I'm also attaching my screenshot from pool math with other levels and open to any other advice.
Thanks in advance.
Jeff
Thanks in advance.
Jeff
