Hi There - I had a 20,000 gallon pool built through last fall that had the liner installed in cold weather.
Got the pool fired up the other day just to ensure all equipment was running properly, and had some hopes of getting the pool filled and heated to stretch the liner into the corners and steps (which are all 90 degree).
We have a friend in the pool industry (30+ years) so he supplied the equipment and liner, and the pool builder did the install. Pool builder feels the liner is a bit "tight", and the euqipment supplier thinks it was measured right / installed wrong and needs to be reset. As you can see formt he pics attahced there are some wrinkles to deal with and the corners do not fit at all anywhere...
Thoughts on if the liner will fit? The pool builder is being good and agreeing to do what he can to adjust / reset as needed.
