I see problems.Test results from the daily test are below, how do I know if it needs anything based on these numbers?
CL - 1
BR - 2
PH - 7.2
FC - 8
Cc - 0
CH - 150
TA - 130
Cya - 40
should I add anything today? Pool math says a ton of soda ash and acid.
I see problems.
1) You don't use Bromine, so the BR reading is useless.
2) CL and FC should be the same, or at least close. They're both reading the chlorine level in the pool, and there's no way you have 1 and 8 at the same time. Even if you used the wrong factor on the drops, they're still not even close. If you're unable to distinguish the shades of yellow on the CL test, don't use it.
3) There's nothing wrong with the pH and the TA levels. What numbers did you put in as your targets?
Today's results
CL - 5
BR - 10
PH - 7.5
FC - 9
CC - 0
CH - 175
TA - 140
CYA - 50
Any additions needed?
Rain can help to dilute CYA by overflow or if you pump some water out before it rains.Pool math says replace 20% of my water...it rained all day today and the pool is full! Hopefully that helped!
