our pool designs result in a TON of aeration even when not running the waterfalls, which drives the pH up and the TA down.
I'm fairly sure aeration has no effect on TA. The addition of MA to reduce PH does though.
Talking about your chemicals reminds me that I need to get my test kit ASAP!
Pool pump question: It's full of water. It just looks completely empty because there is no air for contrast. Mine looks the exact same way.
Brushing: you just need to knock the plaster dust off. Don't kill yourself trying to scrub it.
Startup: I think they do a traditional startup. Acid startup makes a good smooth/even finish with less brushing (and dissolves the plaster dust) but some think this decreases the life of the plaster
Test results: Be careful of adding much chlorine early on. The water will be pretty cold, anyway, so you are unlikely to have a big algae bloom or any major problem. I wouldn't sweat the pH too much right now. My pool (as a result of my fill water) wants to be at 8.2 constantly. We battle it out and usually agree at 7.9-8 most of the time. My CH is on the low side, so no scale problems, but chlorine is a little less effective at the higher pH. Also, I'm sure they just tossed the CYA in the pool, so it may not have dissolved yet.
On a side note: You will probably from time to time notice that some of the drains in the waterfall "basins" will get air-locked or slightly plugged with debris. Just give them a few pops with the heel of your palm to get the water draining again when this happens. It's just a consequence of the drains being generally hidden.
Another tip: More for in the summer when you are running the pump longer - our pool designs result in a TON of aeration even when not running the waterfalls, which drives the pH up and the TA down. You can turn off the bubbler valve and choke the spa return valve down pretty low to minimize the amount of water that's getting aerated. Doing this really helped to lower my acid requirements. For now, though, your new plaster is going to chew through a ton of acid no matter what.
Fantastic design! Love the waterfall. What type of pool plaster/finish do you have? Also, what about the pool tiles? Thanks
It is safe to fish the leaves off the bottom of the pool with the leaf rake. I had to do the same thing until I was allowed to use my vacuum 30 days post-plaster.
Lights look great. How many you have in the pool
