Is the steel engineered, and are they following that, or do they just do them all this way.
Obviously if you have a engineer that stamped his approval on this then you are covered.
It looks like it is all #3 @ 12 on 12. I can not see it all in the pics.
You have a house load very close on one side, free standing wall on the other, and a fairly deep pool.
I would be 6" OC verticals on the entire house side, with 3" OC verts below 4'6", extending 2 1/2' into the floor.
On free standing side I would use a box beam, basically double wall where it is free standing, and below 4' 6" use 4" OC verts, around the entire deep end. Also want to beef up the break line across the bottom of the pool.
I looks like a 3 bar beam, a 4 would be the minimum in my opinion.
Remember you will be adding almost 150,000 lbs of water into this hole.
