Hey guys,
Amazing forum you got here. Spent few hours looking what people talked about.
I want to build a pool 900x320cm, I know probably you are used with inch metrics, but maybe you can help.
pool will be made from concrete.
So, I have few questions.
1. What type of skimmers should I use? Square or rectangle, and does the size matter?
2. Skimmers can be right at the top of the pool like this one?
3. The layout I provided attached is ok? IF not, how far from the corner should skimmers and return jet be.
4. The return jets how low should it be bellow water surface? The water surface I know it should be in the middle of skimmer.
5. I plan to use a pipe for each return jet, one for drains - will be combined on same pipe, one for each skimmer, and one for the vacuum, is not in the layout yet. I understood that the 63mm pipes, I think thats 2.5 is a good choice.
6. The plan is to use a sand filter and a pump either from Astral Pool or Hayward. I see many options and recommendations, what size it should be? The water is around 35 cubic feet.
7. The stairs I plan to build will be in corner, top left corner, in that case, do I need to move the return jet?
