- Feb 22, 2022
- 4
- Plaster
- Hayward Aqua Rite (T-15)
Hi all-
After 7 longs months (supply chain issues, ugh) our pool is finally up and running. Last Friday (6/24) we had our official startup. Builder's pool school scheduled for next week. I helped with our pools as a teenager so I "know" the basics and I've had plenty of time to read up on things here. Became a TFP supporter without hesitation, bought the TF-Pro test kit, and I'm using Pool Math. Got the basics covered thanks to TFP!
Since we're in our first 30 days we don't have salt in the pool yet, so we're running on a combo of trichlor tabs (3 in feeder until dissolved, then refilled) and liquid chlorine (10%). I'm using the tabs to add a continuous feed of chlorine and slowly add CYA. The "scary" stories of too high CYA and having to drain/fill have kept me from adding any additional CYA. I usually test in the evening and use the liquid chlorine to bring things back up since pool usage, sun, and high temps are using up chlorine during the day.
One week in, and things seem to be going well. I know my numbers aren't perfect, but I also seem to recall that during the plaster curing phase they will move around a lot. So, my question is, anything you would recommend me doing? Bump up stabilizer? I'm adding chlorine every day, should I increase the number of tabs in the chlorinator?
Logs here: PoolMath Logs
Thanks!
Thanks!
