Two things I'd watch:
1 - Increase FC right away to avoid algae. Always refer to the TFP
[FC/CYA][/FC/CYA] to keep the FC balanced with your current CYA. You're probably not using the SWG yet correct? Once you do, you know to increase the CYA to a minimum of 70.
2 - Your pool is currently in the "potential to become scaling" range (0.44) as noted on the
PoolMath. Ideally you want your CSI level (3rd row from bottom of
PoolMath) to be neutral (zero) or slightly negative. Enter all of your test numbers in
PoolMath to see what I mean. You can fix that quickly by controlling the pH rise from new plaster. Use some muriatic acid to lower the pH to about 7.3-7.5. Perhaps even better, keep working on that routine of lowering the pH with acid which should also slowly lower the TA. When the TA gets down to about 100, the pH rise should slow down and it will help your overall CSI level. Also see:
Pool School - Lower Total Alkalinity.
