I replaced an old single speed Pentair pump with a new VS Pentair pump about a month ago and it was working great. It was running for about a month and just today I went out to check on it and it wasn't running. All of the lights on the control panel are lit up green but it won't run and the screen is blank. I tried turning off power to the motor for 20 minutes and turning it back on and it was in the exact same state. I also tried holding down the 4 buttons (1, 2, 3 and quick clean) to try and reset it as well as holding down 1 and +/- at the same time with no luck.
We've had pretty heavy rain storms over the past few days so I thought maybe water got into the wiring and opened up the wiring area but it is dry. I also used a multimeter to confirm that it is getting 240 volts.
I'm looking for any suggestions on other troubleshooting steps that I can take. I think it's under warranty since it's less than 60 days since I bought it but I'm not looking forward to going through that process if I don't have to.
Thanks in advance for any advice!
Kris
Kris
