Hi all,
Found this great website and have been reading a fair bit. I have made some assumptions on what I need to do here but hopefully someone can assist.
See images. Pool is only a few months old, PH rises constantly up around 9 and then ill bring it back down once a week. There was some waste from pebblecrete construction in the filter so I have assumed PH problems are from this ‘fresh’ pebblecrete. I have replaced this filter. For reference, I have dumped probably 15L hydrochloric acid in over a few months. PH usually rises back up over a few days.
Furthermore over time the white pebblecrete seems to be getting brown spots /splotches all over the pooland brown areas around edges. Wall brush does not remove. It’s not terrible but seems to be slowly getting worse. Note the pebblecrete had no brown in it.
Would I be correct that getting the PH down and keeping it a bit lower than recommended ~6.5 might alleviate this problem?
Thanks in advance.
Thanks in advance.
