If you can get the spider gasket out of the valve in one piece you can take it to a pool store and they will probably be able to find you a matching gasket. Or you could try tracing it onto a piece of paper and see if they can match that.
Adding a timer is fairly easy, but it will need to be hardwired in. To pick out the correct timer you need to know if your pump runs on 115 volts or 230 volts.
Yes, the ball valve can handle the pressure in the filter. You can simply leave it installed.
