Hi All,
I replaced my pump motor with the exact same 1Hp model:
A.O. Smith 1 HP, 56Y Frame, Up-Rate Motor (B2853)
I noticed that the impeller that was on the old pump was a rated for 1/2 hp - 3/34 hp (Impeller, C105-92ps Sta-rite (c105-92ps)) so I bought an impeller and diffuser that was rated for 1 HP (same as my motor) : DIFFUSERDURA-GLAS 3/4HP-1.5HP FULL RATED, 1-2HP URATED/ MAX-E-GLAS 3/4HP-2HP FULL RATED, 1-2.5HP UP.
Replaced the seals inside too and then when I power on it will take a while to prime and then when it does prime, it completely loses it in about 3 seconds , the it repeats this cycle of slowly building up to prime , priming briefly, and then losing it all the way.
Does this have something to do with the replacement parts that I upgraded with ?
thanks
thanks
