Thanks Lisa and Kim. LOL yeah, I thought the title was kind of catchy myself.
The reason I'd asked about putting it into this thread is because I wasn't sure if the actual word Pantyhose or Whatever the teaching or questions (that may generate extended answers) needed to be in the Title of the Thread, so it would develop appropriate tags for them to be directed back to it during their search?
That's why I was wondering if I should actually put that info, or any other teaching type things in their Own Separate Thread, with an appropriate title of the subject, in the proper forum section; instead of just including it inside of my Introduce Yourself Thread, so they don't have to filter through the rest of my confusion junk to find the answer they are searching for? LOL I know I worded that weird, but am I making any sense at all? If so, what are your thoughts on it?
Also I have a few questions that I asked a while back, that I'm still curious about the answers. These things might be something that makes no big difference one way or another, but I'm trying to keep my pool at the most accurate levels possible so they don't appear to yo- yo up, and down as bad. It's more like a Friday Morning Pop Quiz lol. Ok everyone pick your pencils up, and you may begin lol.
I know everything that gets done has an effect (regardless of how large or small of an effect) on something else. So understanding which way is the best to make this process as accurate, and easy as possible is always a plus.
1)When exactly should your Chlorine levels during a SLAM be checked? In other words, does it make a difference on how accurate the levels will be depending on the time they are being checked? (I'm not referring to the time of day). See example questions below:
a)Will the levels be as accurate before a brushing, as they are after a brushing? Is it better to brush first then check your levels, or check your levels then brush? (Here's my thoughts on this: If brushing 1st (which is probably the best way), but then once you add Liquid Bleach after your check, you have to brush that area again to help mix it up so isn't that extra work? is that correct?)
b)Will the levels be as accurate before vacuuming as after? Is it better to vacuum 1st then check, or check the levels then vacuum?
c) Are the levels even close to accurate if checked in a pool where the pump has Not been running for at least 30 mins-1hour before they are checked?
For example if someone was in the middle of a SLAM, and their pump broke, yet they couldn't get it repaired until late afternoon; should they check the level in the AM anyway, and try to adjust the chlorine levels accordingly so they don't fall below SLAM, (although they can't circulate it, they can mix it a little with the brush), or do they just not worry about dropping below SLAM until after their pump is repaired, then start their Slam again if the levels have fallen to low?
2)When needing to add water to you pool, is it best to check the levels before the water is put in, go ahead, and adjust up to SLAM if low?
or
a)Is it best to wait until the new water is all in then check the level?
or
b) Would the most accurate way be to actually check the levels both before, and after adding water (which will of course use more chemicals, but at least the pools that are close to SLAM, won't drop below SLAM level during the water adding),adjusting SLAM level both times accordingly?
Ok that's all the questions I can think of right now, lol I'm sure there will be more to come soon.
My 7 AM FC-16 Adjust up to my SLAM level of 17, CC-.5. I'm again having to add water uggg, so I'll see (out of curiosity) how much it changes the levels after all the water is in.
Have a Wonderful Day!!! and Thank you all for everything.
