Hi all! I am replacing a now dead Pentair WFE-28 with a variable speed intelliFlo VSF. I will no longer need the timer which operated the filter pump, so I figured it would be best to upgrade electrical at equipment side using a load center that can mount on exterior wall of house. I have to incorporate the PA 220GF upstream of the new filter pump, and a new load center will give me a spot to house this GFCI breaker.
The pool is very basic. Installed in 1998. No automation or newer fancy features. One light in pool, and one in spa. Both on their own light switch. 120V halogen, as I see no transformers anywhere to indicate lower voltage lights. The new pump (and newer - to current code electrical work performed) will be the coolest up-to-date thing about this pool. Will be nice to have everything organized and labeled in the box.
I am looking at a few of the Intermatic pool/spa load centers. Something that can house most of the equipment side electrical, receptacles/light switches, disconnect switch, etc. There are load boxes that come with or without extra spaces for timers. I figured that there is no longer a use that I can think of for a timer in my situation with this pool setup (given the new intelliFlo VSF)... but, maybe I am missing something? Maybe I have not thought of some future need for a timer, where it might be useful for the load center to have the option to add a timer or two. Also, is it code compliant to have the disconnect switch (shutoff power to filter pump) in a switch spot in the load center box? Or must it be located outside of load center in its own junction box? Right now it is in a junction box that shares the two switches for pool lights and the blower switch.
Here are two pics of the box types I am considering... on with timer spaces, and a box with no timers. Just space for breakers and receptacles.
Any thoughts on whether or not a box with timers may be useful now, or down the road. Just looking to keep it somewhat simple and get the pool filter pump back on line. Appreciate any thoughts!
