When we did original dig, all of the blocks, legs, etc were dug down some. When we needed to re-level, we did not need to raise any one of the legs or blocks a large amount. The largest was maybe 1", the rest were less than 1". This meant that the amount we needed to build back up was "contained" within the original dig area of the blocks, with good solid ground under and around the filled dirt. We compacted the filled dirt before place the block back down. My concern was the area between each of the blocks and legs where the bottom rail runs. The ground under the rails right now varies from touching the rails to about 3/4 inch max gap. We attempted to build this up with some sand and soil, but, since this area is not "contained" it is difficult to get the filled area to stay in place. I was wondering if there was a better base material that could be used under the rail that would form a better base. In the end, Most of the bottom of the pool will get back filled. Thoughts?
