- Dec 5, 2012
- 99
Hi,
Been lurking awhile as my wife and I have been discussing getting a pool. Finally decided with the interest rates so low to refinance the house and start a pool. Started getting bids from PB's the last week of April. We have finally decided on a PB that did one of our neighbors pools and is also the personal friend of that neighbor. Great guys and easy to work with.
We just gave them the go ahead on Saturday so they should be lining up the applications and permits today. Probably be 30 days until it gets through our HOA and they can start digging. Now the wait begins...
I'll start including pics as soon as there is any to share. In the meantime I have included the specs and the blueprint.
BTW, great site. It has been an immeasureable help in our choices of equipment and style.
General Specifications
Style - Custom
Size – 24’ x 26 ½’
Pool Square Footage – Approximately 513 Square Feet
Perimeter - 107’
Depth – 3 ½’ x 5’ x 4’
Structural Specifications
Excavation - Bobcat Dig
Steel Schedule - #3 Reinforcing Bars 8” O.C.
#3 Reinforcing Bar Deck Dowels 32” O.C.
Pool Structure - 4000 PSI Gunite (6 ½ Sack Mix)
Walls - 6” Minimum Thickness, Floor - 6” Minimum Thickness
Coves - 8” Minimum Thickness, Bond Beam - 12” Box Style w/ 4/#4 Reinforcing Bars
8’ Custom Double Wall Spa, Raised 12”
Bench (with step-up) around Spa
18’ of 12” Raised Double Wall, finished on all sides
2 / 3’ Sheer Descent Waterfalls, 3 Bubblers in Large First Step
Pool Equipment
Filter – 100 Sq. Ft Pentair Quad D.E. Cartridge Style Filter
System Pump – Pentair IntelliFlo XF
Water Feature Pump – Pentair 2 HP Whisperflo
Pentair EasyTouch 8 Automated Control System, with IntelliChlor and Wireless Remote Control
Heater - 400,000 BTU, Electronic Ignition, Low Nox, Pentair MasterTemp
Cleaner – Pentair Legend (w/ Booster Pump)
Erosion Type Chlorinator - Rainbow 320 In-line Automatic
Pool Lighting - 2 Pentair Intellibrite 5g White LED Pool Lights
Spa Lighting - Pentair Intellibrite 5g White LED Spa Light
Main Drains - 4 Anti-Vortex Pool Drains, and 2 Anti-Vortex Spa Drains
Skimmers - 2
Returns - 6 Directional in Pool
Spa Jets - 8 Waterway Deluxe Series in Side, 4 Floor Jets
Air Blower - 1 ½ HP QT
Plumbing Specifications
Pipe - All 2” Schedule 40 (except as designated below)
2 ½” Schedule 40 Spa Return Pipes
3” Schedule 40 Spa Suction Pipes
3” Schedule 40 Manifold at Equipment Pad
1 ½” Schedule 40 Cleaner Return Pipe
Separate Skimmer Lines and Main Drain Lines to Equipment
Pool Miser Automatic Fill Line w/ Anti- Siphon Valve Included
Spa Boost Bypass Plumbing System Included
Pool Coping and Tile
Nysa Travertine Coping
Waterline Tile – Standard Choice
Spa Facing, Front and Sides of Raised Wall Facing – Honey Gold Classic Split Faced
Back of Raised Wall Facing – Standard Tile
Plaster – Pebble Sheen (Level 1 Color) - Aqua Blue
Pool Decking and Drainage
Pool Decking - 603 Sq. Ft of Walnut Tumbled Travertine Decking atop 4” Poured Concrete
Concrete Reinforcement - #3 Reinforcing Bars tied on 14” Centers
Deck-O-Seal between Pool Coping and Decking
Gutter Drain – Yes, Tied into Deck Drains
Deck-O-Drain between House and Decking
Deck Drains to Street
Utilities Included
Pool Heater Gas Line - 1 ½” Poly Pipe – All Footage Included
Pool Electrical Hook Ups - All Footage Included
Electrical Sub-panel – EasyTouch
Maintenance Equipment
Brush, Leaf Net, Telescopic Pole, Test Kit, Vacuum Head, Hose
Start-up Chemicals Included
Pool School Included
Site Clean Ups
Gunite Clean Up
Final Clean Up
Warranties
25 Year Structural Warranty
Equipment Warranties by Manufacturers
Extra Items Included in Bid
GFCI Protected Electrical Outlet and Light at Equipment Pad
Volleyball and Umbrella Anchors
Multicoat Mulasticoat and Scratch Kote Application to Pool and Spa upper interior area
Approximately 266 SF of Concrete Break Out
Added
Screenlogic 2
2 Intellibrite 5g Pool Lights and 1 Intellibrite 5g Spa Light
3 ColorCascade Bubblers
~TexSS
Style - Custom
Size – 24’ x 26 ½’
Perimeter - 107’
Pool Equipment
Skimmers - 2
Utilities Included
Site Clean Ups
Gunite Clean Up
Final Clean Up
Warranties
Added
Screenlogic 2
~TexSS
