- Jun 22, 2014
- 47,857
- Fiberglass
- CircuPool RJ-45 Plus
That's correct. 10 ml sample size, one heaping scoop of powder, number of drops until clear divided by 2 (i.e. 14 drops = FC of 7).
I'm assuming those numbers above are from your TF-100 correct? FC is zero. Have you tried adding any bleach yet? Since you have new (fresh) water, you should do the following:
- Add stabilizer for a target CYA of 30 to start with.
- Add bleach for a day 1 target of 3 ppm. After that, increase to about 5 ppm.
- pH is a little low. Ideally you want it around the mid 7s unless you have to "SLAM" for algae, but with fresh water you should not have to do that.
- CH is fine and TA is slightly elevated but can wait for a while.
Let us know if you still have questions.
