You should try to minimize pressure on the solar panels, they should see a peak of about 10 psi (ideally less than that), if they were set up right there should probably be a valve to bypass some of the flow around the panels. This pressure should be measured at the panels or at the line going to the panels compensating for the pressure for the height to the top of the panels, a good rule of thumb is each psi equals about 2.2 feet of water column. So if you have a roof mounted panel with the top at about 15 feet above the height of the pressure gauge it would read about 7 psi when their was 0 psi and no flow at the top of the panel. This could probably be worded better but it is almost 2 am here. So to sum this up you generally only want enough flow out of the solar panels so that the water coming out feels only slightly warmer than the water going in, but not so much flow as to over pressurize the panels. Think a steady flow, not a gusher.
