Construction of our 15000 gallon gunite pool ended about a month ago. It has a salt water chlorine generator, but the salt hasn’t been put in yet. We brushed it twice a day for 2 weeks. The plaster is supposed to be Pebblefina Acquos, but it doesn’t look like it, and I don’t think the flecks were sprinkled into it during plaster. It looked pretty blotchy and still does. We did not get into it until a week after plaster and were very gentle on it during this time. The pool builder hired a maintenance company to take care of chemicals for two weeks. They only came 3 times in those two weeks. After their last visit, I tested the water with the test kit the builder gave us. There was no chlorine in it, the pH was over 8 (that’s as high as the kit reads), and the TA was 110.
I wasn’t sure if those results were valid, because the kit had been left outside for a while. I went and bought the Taylor K2006 and the test results were the same. I did not elect to hire the pool company after this, because they did not add anything during their final visit, when it clearly needed chemicals.
I added about 1/3rd gallon of chlorine that evening, and it was gone the next day. I also added muriatic acid by diluting into a bucket and pouring around the edge of the pool, then brushing to stir and clean the plaster. After doing this, we noticed even more white blotchy staining the next day.
We then went on vacation and I simply told the person staying at our house to check chlorine levels and add a half gallon when low. It consistently is gone almost as soon as it’s put in.
Question is, does the plaster blotching go away? I tested CYA today and there’s none. Any suggests for adding?
Sharing my pool info here from Pool Math:
Oasis
Build Type: Plaster
Volume: 15000 gallons
Latest Test Result Summary:
FC: 0.0 (13 minutes ago)
CC: 0.0 (13 minutes ago)
pH: 8.2 (13 minutes ago)
TA: 110 (13 minutes ago)
CYA: 0 (13 minutes ago)
TEMPERATURE: 80° (14 days ago)
Test Results 06-25-2023 @ 09:08 PM
Free Chlorine: 0.0
Combined Chlorine: 0.0
pH: 8.2
Total Alkalinity: 110
CYA: 0
Oasis
Build Type: Plaster
Free Chlorine: 0.0
pH: 8.2
CYA: 0
