Hello all, I have a pretty straight forward setup. I upgraded to a vs pump about 2 years or so ago. I’m now looking to change up the filtration system. I’m over this cartridge cleaning, and im finding some blow back, I’ve tried new filters making sure they are seated well but no luck. The filter housing is probably at least 15 years old. Perhaps that’s the issue.
My question is where should I start to explore? The gentleman at my local pool supply talked about a glass filter system.
What about adding a SWG?
Whatever suggestions you have are appreciated. I’m not versed on the equipment side of things. Also Polaris booster is getting the boot. I purchased robot cleaner after replacing the booster pump multiple times. I would also note the floor drain is capped. Only using the skimmer. Pool was built in the 70s. I’m in south texas with weeks on end of 100+ temp looking to be the norm.
