So I am thinking when I install my new filter booster pump I will need to rework the current suction piping to get a little more height and it is in bad shape. I was going to cut the three existing risers at or slightly below grade and then install a new 2-inch coupling on the risers. The only part that is making me a little nervous is getting all three new riser sections to the extract same height and then cutting the small spools of pipe between fittings so the dimensions are correct left to right on the risers. Just wondering if there were any tips or tricks on something like this and if this can be construed without putting stress on the existing underground pipes since I cannot move their locations. Think this is doable?
