We’re having a fiberglass inground pool installed in May. It will be salt water and we live in Central Texas. We’ve never owned or maintained pools. Can anyone recommend/link a good thread for proper water maintenance in this type of pool?
It's hard to know when we don't know your other equipment, see my 1st post, sizing is very important (how many gallons is your pool), type of pump, if you are using automation, there are quite a few options so try to find out your pool info and get back to us.
Hello mah2496!Can anyone recommend/link a good thread for proper water maintenance in this type of pool?
You're absolutely correct.I was under the impression that I wouldn’t use/need chlorine pucks for my pool. I was told I just needed to add salt to the pool. Am I misunderstanding something?
Is it possible that your builder is just putting salt in the water and you are not actually getting a salt water generator (SWG)? Do you know if there is actually a salt water generator, based on your pool size you probably want a 30K+
Completely different things. The in-line chlorinator is just a small (vertical) cylinder items installed in the plumbing that holds chlorine tablets. An SWG is also installed in the plumbing line, but is smaller and has access to power to generate free chlorine from salt water. Either will work with your pool, but you'll want to confirm so you know how to plan later. The SWG will generate free chlorine without any assistance from you. The in-line chlorinator (with tabs) is only used for short-term chlorinating because the tabs increase your stabilizer levels in the water (bad). If you don't have a SWG, you'll be adding chlorine (aka bleach) to the pool manually. Not a deal breaker, but you need to know.I wasn’t sure if the in-line auto chlorinator would serve as the SWG.
My builder said he miscommunicated. I will have a salt cell rather than an in-line auto chlorinator.
