Schwimmbad
- Sep 4, 2022
- 323
- Plaster
- Pentair Intellichlor IC-40
I ordered this one from marina pool and spa Polaris R0897800 Fine Filter CanisterJust scrolled back a bunch of months and found the new 'finer' filter. Is it this one?
A question to those of you who have the fine filter, or have tried both … is there a reason to not get just the fine filter?
Will it have issues with large debris ? I tend to hard a decent about of leaves but also some sediment. Just curious why the regular filter would be needed at all if the fine would handle everything
Thanks …
Mark,t seems to me the robot should at least suck up these large piles of dirt and spit them elsewhere on the pool floor.
I just purchased the EVO 614 and have been trying to decide if I need a caddy. I like your solution!Slightly different than the issue of fine dust, has anyone else had an issue with small debris escaping the basket and expelling from the impeller/exhaust port on top (apologies if this has already been asked/answered)? We have small seed-like debris this time of year and on the maiden voyage of my new 614iQ I noticed debris coming out of the impeller. Plenty stayed in the basket of course but there was enough to notice. Perhaps my unit is not getting a good enough seal around the rubber gasket on top of the basket? Here's a photo of the basket with debris. As you can see, there is a little debris up in the lid and outside the sealed basket area (when lid is closed) as well as buildup around the rear of the basket upper seal.
And totally unrelated, I'm happy to report a successful repurposing of my Dolphin S300i caddy to accomodate the 614iQ robot and power supply! I removed the old Dolphin power supply from the caddy and the new 614iQ power supply simply dropped over the upper mounting bar and was supported by the lower lip. Though not an exact fit, it only had a little wobble. One large zip tie later and it works great!
View from below, looking up into the mounting area.
I just received my eco 614 today and tested it out on my dirty pool. I decided that I need a caddy. I have space on my patio to set it but I simply now want it off the ground. I found and ordered a “Polaris caddy cart for robotics “ is their generic caddy that works for all their machines..I just purchased the EVO 614 and have been trying to decide if I need a caddy. I like your solution!
I have always used the fine filter on my robot for everything. If I am cleaning, it might as well be picking up everything.I just ordered EVO 640iQ as well, with an additional filter. I think it makes sense to use the fine filter for dust maybe once every 2 weeks, but use the standard for daily cleaning of leaves.
you thinking it might be a waste to have 2 types of filter? it's $50 not cheap, I could still cancel the regular filter...not sure how much better for leaves (and drag/longevity) vs. using the fine filter. If anyone has tested or compared them in action please let us know.I have always used the fine filter on my robot for everything. If I am cleaning, it might as well be picking up everything.
Correct. I never use the coarse filter for my robot. Not sure why you would choose the coarse over the fine. Now I do not own an EVO, but my Dolphin never misses a leaf or dirt when I use the fine.you thinking it might be a waste to have 2 types of filter? it's $50 not cheap, I could still cancel the regular filter...not sure how much better for leaves (and drag/longevity) vs. using the fine filter. If anyone has tested or compared them in action please let us know.
