- Feb 23, 2023
- 3
- Vinyl
- Hayward Aqua Rite (T-15)
Hello all,
I am in about to start my 24’x44’ in ground vinyl pool project. I have been searching these forums, and can’t quite find an answer to one part of the build process.
I am using 2” sureflex PVC as that is what is been recommended by most people here in NorthWest Indiana that have had pools installed. Once I pour my concrete bond beam, should I put down a couple of inches of pea gravel, run all the plumbing, than cover the plumbing with pea gravel. Once the plumbing is covered, fill the balance with 3/4” clean gravel. I am using 16”x24” pavers for the deck.
There is a pretty good chance also that I will have to deal with a moderately high water table. I was planning on digging a dry well adjacent to the deep end and install a sump pump. In researching this, I have read a few people have poured the hopper floor in concrete in lieu of using pool base. Any comments on this would be much appreciated. Do to the location of my build, I have to use a pump truck for the concrete work, so pouring this at the same time as the bond beam wouldn’t be that hard.
Screen shot of my build model attached.
