- Sep 5, 2020
- 374
- Plaster
- Jandy Aquapure 1400
Morning folks. Searched and found a few discussions about this but was 2017 and earlier so wanted to post a new thread for any new info found since then.
We are having plumbing/electrical installed this weekend and our neighbor who is using the same builder had there autofill/pool pad water hooked up to the irrigation line instead of the nearest hose bib.
I ran it by my construction manager who confirmed we can do it as well if we choose (no additional costs as well).
I am going to get more details Saturday when I talk to plumbing sub as my neighbor can't recall seeing any valves or what have you installed near the sprinkler valves for the pool water lines. Some of the threads I found mentioned pressure valves or something to that effect that should be installed? He is on vacation and said he will check when he gets home but that will be after our plumbing goes in so I want to get this down right.
Lastly, I wanted to talk about the downsides. Here is what I came up with while searching. Any merit to warrant concern?
1. Possible water contamination issues from irrigation lines with fertilizer/pest spray/animal waste/etc making its way into pool lines. We are in Northern California but I saw the thread about Texas having municipal codes not allowing this type of connection due to these risks.
2. What if I need to shut off irrigation valves to do irrigation sprinkler work in cases of leaks etc? Our irrigation line connects to the house main water line via a T connector, and there is a shut off valve right there for the irrigation lines (if that makes sense?). If I shut this valve off then that would shut off my autofill correct?
I like the idea of not connecting to hose bib but not sure if it's a better choice.
Thanks for any input. Will post pictures of our irrigation area later when the sun comes out.
