Thank you for asking... There is a linear deck drain under the tapeWas a foam strip placed against the previously poured deck?View attachment 479769
The weather was perfect for plaster - 78 degrees and no wind.
Many reasons - Kasa app is much more user friendly than the screen on the pump. I usually run my sheer as a return, and it's nice to turn it off via phone if it's windy outside. It's easier to sync the Kasa controlled SWG with the app.You might be able to use a relay that is triggered with the low voltage wire to switch the higher voltage to the pump.
But why? A VS pump is designed to always be powered on. It should not be switched such that power is removed. You use the scheduling feature on the control pad of the pump if you do not have automation.
Just remember, the pump is not designed to be turned on and off by removing the power to it. The electronics are designed to be powered on all the time.Many reasons - Kasa app is much more user friendly than the screen on the pump. I usually run my sheer as a return, and it's nice to turn it off via phone if it's windy outside. It's easier to sync the Kasa controlled SWG with the app.
