Hi all, we are close to finalizing the details for a new pool construction in DFW. I wanted to run some of the details by everyone here who have way more pool experience in order to get in front of any major red flags we may not be aware of. Attached are the details of the quote.
Pool size:
Equipment list (note some things have changed from the attached quote, this list is the most up-to-date):
So I am currently trying to push for SWCG, but no part number yet. Is there a Jandy SWCG you guys would recommend? I am concerned about corrosion, especially on the decking and metal structure since they aren't cheap, but have no first hand experience with it happening so I am relying on the perceptions of others (pool builders and service people who say SWCG is going to corrode everything, and owners who say they would never go back).
Thanks in advance for any and all advice!
Pool size:
- Pool and Spa: 495 SF / 108’ Per.
- Dimensions: 36’ x 16’ Depth: 4' X 5' X 4'6" EST. Gallons 12,890
- Main circulation pump: Jandy Pro Series ePump 2.7hp variable speed: #VSSHP270DV2A
- Water feature pump: Jandy Pro Series pump 2.2gpm: #VSSHP220DV2A
- Polaris quattro robotic pool sweep : F4TH
- Polaris booster pump: PB4SQ
- Jandy CL580 filter: #CL580
- Jandy Jxi 400K BTU gas heater: JXI400NK
- Polaris 1.5 HP air blower: PSB215
- 12 W LED color pool/spa lights : JLU4C12W100
- Pool control: iAquaLink automation kit : RS-PS6
- Sub panel: 6614-LD
- iAquaLink: 1Q30-A
