Ok Im learning as I go
apparently the hard way
AGP 24 Round 54 tall 15200 Gallon
We filled the pool from the tap took a day
I am using salt
added 320 ponds of salt
I am using a Saltron Retro
I have green light for good salt level.set to run 20 hrs a day for now
I ordered the TF-100
So the SWG is running I see the smokey exhaust
Water is super clear
I get my kit and check FC and PH
FC=0
PH=8.2
I figure i need to add Chlorine, I do some more research and check the Pool Calculator
According to it I need to add 168 oz of 6% Bleach
I get that at Walmart I add 182 oz
Today I check again and also check for CYA, after doing more research
FC=0
PH8.2
CYA=0
SWG still running 20 hrs a day Pool still clear
Im confused how the CF still equals Zero
So tonight I added Smart Liquid shock 1 gallon and 6 oz of HTH #2 it says Trichloro in a floating container
I think if I did my home work that the HTH will bring up my CYA
I bet I will still need to add a conditioner to bring it up to 60 or 80
But the store was out, I hope my wife gets it at lunch tomorrow.
I will run all of the tests tomorrow after work
I am sure that once everything is balanced the SWG will work just fine, and I should check Cf every couple of days.
What else am I missing? I will run all of the other tests after I get the CF-PH-CYA all set, I just didn't want to get to overwhelmed and I am already it appears
No pool use as of yet I hope to have everything squared away for this weekend
I am using salt
FC=0
PH=8.2
FC=0
PH8.2
CYA=0
