That is great! I have another one that is having a hard time getting the TA to come down much at all. So keep doing what you are doing!
Kim:cat:
Kim:cat:
Kim:cat:
Thanks for the contact, we will keep him in mind when we get quotes.Nate - everything is looking great. Blue barn nursery in Sycamore/Genoa area, Jim I believe, might be a good asset to come and look at your landscape. He did our's at a previous house. We told him what we wanted and noted our small budget and he picked low maintenance, but several bushes/trees. We moved forward with his drawing and most of his suggested plants and then added a few more ourselves over the next year or so. He owns his nursery so I don't think i could have done half of what he did for the money myself.
Also, you can use the "effects of adding chemicals" at the bottom of the Poolmath tab to see what MA/dry acid will do to your TA. Always nice to be able to confirm your test results.
NICE JOB! That looks awesome!
I would LOVE to see the lights on the tall posts on at night. I bet they look great. what a neat idea!
I hear you on the gate by the equipment. We had to add stairs to that area as well as a gate and railing they kind of "forgot" to put railing all the way around the deck! (nothing was "finished" with ANY projects he did)
At least you can jump in the pool when ever you get hot and want to cool off!
Kim:cat:
I will be in Baton Rouge on Monday but only half a day, can't build a deck that fast! I can encourage and send good vibes though!What a great build. Now, can you come over and build my deck? LOL!
Ouch!! That's one way to get some stairs....I had a bucket for me to use to help me get down to the equipment BUT when it turned over as I was stepping down on it that was the end of that! Hubby went out right then and bought the stuff to make steps for that area! The air was BLUE for a few mins after that! LOL
Kim:cat:
We have about 3-4 foot access under the deck. You can frame the pool with decking and then you can remove those pieces if you need to. We almost did but I figure I will just remove a few deck boards if needed. Our deck goes up to the cap so we would just need access to the post caps to remove. It wouldn't be fun but we could remove those boards in a few hours if needed. Just make sure you buy good screws. We got the premium ones with the Torx heads.We are wanting to do a deck right up to the edge of our pool like yours, but not sure how we would access and remove the caps to change the liner since ours is buried. Do you have access from underneath the deck?
