I wanted to heat the pool with solar while at the same time, heat the spa with the gas heater. The Filter pump is configured to heat the pool or the spa. When the spa is heating with the filter pump, you can't use the solar panels. I have a Feature pump that normally just circulates the pool water, separate from the spa. I installed two 3-Port Diverter Valves, 2" x 2.5" (Pentair 263028) and some piping to allow the Feature pump to heat the pool with the solar panels independent of the Filter pump. Now when I turn on the spa mode to heat the spa as in the past, the level in the spa slowly drops. It will eventually drain the spa completely (I should mention, wife not happy?). Since the only change is the new diverter valves and I believe they are leaking spa water back into the pool. I have inspected the new valve internals, and everything is clean, the valves look new, as they should. There are numerous other ways spa water could leak back to the pool. I've checked the internals of those valves too and they look normal. It is a complicated system and difficult to explain all the details. I think the question is, how much do pool valves leak? Is my loss in volume somewhat expected? I don't think it should be expected as the original identical valves do not leak. Thoughts and what the next steps I should consider are appreciated.
Returning the valves are not really an option as they are glued in, and I bought them 1.5 years ago. I bought them and they sat in my garage for a while...
