Blink said:All of you are the best! He is running to stores now to get the goods. I will report back later tonight or in the morning on my findings. I will follow the levels in the calculator depending on my TA test and CYA test and work on PH first. I just wish that CYA test is not so subjective. Filling the tube until the dot is covered is a little bit of a **** shoot as to when it is “truly” covered. Thanks All!!!!
You can pour it back into the mixing tube and then run the test over until you get a sense of where it is really at.
