Hello all!
I have a Triton TR100 sand filter and I need to pull the sand to replace the drain assembly because the black drain part that screws into the filter housing has cracked and is leaking. If someone knows how to replace the drain without pulling the sand I am game to try that. Part that needs to be replaced is: Drain
The filter has pea gravel in the bottom and sand on top. The pea gravel/sand was replaced in 2019. Should I just deep clean sand in the filter before I pull it out or is there a better way to clean the sand outside the filter?
The filter is filtering fine so I would rather not replace the sand
Thanks!
Thanks!
