Need some options for replacement of failed LED lights
Jan 18, 2016
157
Hey all,
I need some thoughts on replacing some failed LED lights. My pool was built by one of the big AZ pool builders about 7 years ago. They used BlueSquare Spectrum 360 color LED's for the pool and spa. I have 3 of these altogether. I'm pretty disappointed as I don't run these lights super often, and two of the three have failed already. I feel like I am stuck with BlueSquare replacements as the housing that has been gunited in appears proprietary. Anyone have thoughts about what to do here? Pics to follow.
-J
Contact ...,
their Pool Tone lights may fit.
Did you find an alternative? I have the same issue with my lights. 3 of them.
Have had the pool 3 years and have already replaced each of them. Called BlueSquare and they wont work with you unless you are a dealer. Had pool service company call them and they made them sign up to be a dealer to then only tell them they would sell them new lights.
Spa light is out again... These lights are junk!
I’m in the same boat. I have 3 of the spectrum 365 color lights in my pool and they have all been replaced twice now. So that’s 6 faulty lights in 3.5 years. I don’t have high hopes for my current ones to last all that long.
Did anyone figure out if there is an alternative that will work with this niche?
Hi, I am having the same issue. Did you replace it yourself? Where did you order replacement bulbs from?
Did you ever get your problem resolved? I too have a Spectrum 360 pool light that was supposedly an upgrade by a large AZ pool builder. My pool is going on 7 years old and light is very very dim so looking for new brite blue bulb. Blue Square is NO help, the warranty on this fantastic upgrade is only 3 years and they don't sell bulb, just refer me to builder who charges outrageous $$ for service and parts. I did find TS Pool Supply on line that sells just the bulb for $270. Called Litchfield Pool & Supply in Litchfield Park, AZ and they say they offer Spectrum parts so going to take a ride down there to make sure.
No .. I gave up. I called presidential pools, they said blue lights are $400 and I can pick up after a week. Dealing with pool pump issues so will fix lights later. Did you end up ordering on TS pool Supply?
