Really like the forum and have learned much from several threads so thanks for everyone who is active on the forum.
We have a 20 x 40 rectangular pool that we are renovating along with the surrounding decking. Had a number of issues already arise and am increasingly nervous about some elements of the redesign. The biggest issue at present is our desire to add a sun shelf. Our pool is 10' deep in the deep end and the shallow end (3-4') starts sloping substantially about 15' into the pool. When we started the dialogue with the PB, we discussed not wanting to use all of the shallow end for a shelf and his suggestion was to dig a 10 x 14' shelf on the deep end of the pool.
We have ample space outside the deep end of the pool so we are probably moving forward with this, but have the following questions:
Any help is appreciated. My wife is using her friends husband as our PB and this project has been less than smooth to say the least. He seems to be clueless and I am not sure of the company he is using to do the construction. We are through demo and it is bad enough that I am considering pausing and having others bid on the work. I should have been more involved, but my wife wanted to run with this. Hoping we are not too far off course, but nervous. Any thoughts are greatly appreciated.
- Shelf in deep end - we do not have younger kids so the shelf is primarily for adults lounging (will have two chairs and umbrella), but obviously might have kids over occasionally and assume they will be on the shelf. I am nervous about the shelf being next to a 10' deep end so we are trying to do some sort of barrier (i.e. stepping stones where the water runs through channels). Question is if anyone has done a shelf in the deep end and if so how did you contemplate this issue?
- Tie in to current shell - the original thinking was to tie into the shell, but when the PB talked about the stepping stones / channels he also indicated they would not have to tie into the shell. The have dug a 3' hole for the shelf and are going to tie the rebar soon. I had always assumed the shelf would need to tie into the shell to avoid them shifting differently resulting in cracks. Has anyone done something similar and if so what is the result?
- Water circulation - the current plan is to have a return on the shelf to keep the water circulating since it will be sitting above the water line of the pool. Does this seem adequate and/or do we risk having stagnant water in the shelf?
- Workers damaged the shell on the deep end - someone did not get the memo and started to demo the shell on the deep end assuming we were going to tie into the shell however many feet down. Fortunately my wife was home and ran outside to stop limiting the damage to a 3' section. PB assures me they can shoot shotcrete and it will be seamless, but my other concrete projects have made me wary of cold joints and I am nervous it is a crack waiting to happen. Is this going to be okay?
